April 18, 2023 at 12:16 pm
April 20, 2023 at 2:34 pm
Dave Looman
Ansys EmployeeProbably not, but you could see if /shrink,0.1 makes the display easier to interpret. I think this will do the opposite of what you want though.
April 21, 2023 at 12:04 pm
Suren Malumyan
SubscriberHi Mr. Dave Looman,
Thank you for the response,
I just need the bar's length to be smaller than the mesh's one, because I want to model nanotubes in the cement matrix,So, how can I model this composite? -
April 21, 2023 at 1:38 pm
Dave Looman
Ansys EmployeeSo it's not a graphics issue, you don't want the reinforcement to be terminated inside the element? For that you will need to create thin, unreinforced elements between the reinforced elements. You can imagine that a finite element shape function couldn't support a discontinuity like reinforcing starting and stopping inside the element.
April 21, 2023 at 3:01 pm
Suren Malumyan
SubscriberUnderstood, but in that case how can I add those thin elements in the beam?
I want to model CNTs (Carbon Nanotubes) in cement beam. CNTs are nanoparticles distributed within a matrix.
There is examples from some articles where authors used these particles in composite specimens by using Ansys.
The example is shown in the figure below.Regards,
Suren Malumyan
April 21, 2023 at 3:47 pm
Dave Looman
Ansys EmployeeYou would need to slice up the geometry so you could mesh the unreinforced domain separately.
April 22, 2023 at 3:04 pm
April 22, 2023 at 4:18 pm
Dave Looman
Ansys EmployeeAPLD geometry creations is documented in the APDL Modeling and Meshing Guide. The approach I envision is to create the entire domain first with the BLOCK command and then slice it up with VSBW (Volume Subtract Work Plane). The location of the work plane is specified with the WPLANE command. After you have an initial position for the workplane it's easier to move it the next location with the WPOFF command. After you made the slices in one direction you would specify a new rotated workplane with WPLANE. So the commands would be:
/PREP7
BLOCK,...
WPLANE,...
VSBW,...
WPOFF,... ! Repeated commands could be in a *DO loop
VSBW,...
WPOFF,...
VSBW,...
WPLANE,... ! Rotated workplane
VSBW,...
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5346
3345
2471
1310
1018
