dislocated revolute joint
    • alejandrojginerd232000
      I'am doing a static simulation of a suspension system but the revolute joint conecting the side plates and the main plate starts moving.
    • peteroznewman
      The model is overconstrained. Delete the second Revolute joint. You only need one.
      Under Analysis Settings, change Large Deflection to On.
      If this answers your question, please click the Is Solution link below (while you are logged in), or ask a followup question.
      Thank you verry much for your answer.
      I have another question.
       I want to know the system reaction force under compresion to aproximate the suspension to a nonlinear spring but the joint probe at the wheel indicates 0 force. Is there another way to perform this study?
    • peteroznewman
      Insert > Probe > Force Reaction.
      Scope it to the Remote Displacement.
Viewing 3 reply threads
