June 16, 2022 at 7:32 pm
schinta3
SubscriberHello,
I have sampled (n,k) data from a Spectroscopic Ellipsometer. I have a very good fit in the coeffiicient model for the with some tweaking in the material explorer. However, I want to compare my FDTD simulation to some other EM simulation methods. How do I extract the MCM model being used by Lumerical
Best,
Sreyas -
June 16, 2022 at 8:24 pm
Guilin Sun
Ansys EmployeeYou can use getfdtdindex which gives you the fitted data: https://optics.ansys.com/hc/en-us/articles/360034409694-getfdtdindex-Script-command
- Error on Lumerical device
3648
2530
1745
1226
578
