Display animation of analysis results
    • ESL
      I am Japanese student and using ANSYS for my research.
      I'm having trouble viewing the animation of the simulation process.
      I use unsteady simulation, and the contour diagram that appears after the analysis completed shows the situation at the end of the simulation.
      I would like to show the animation of the fluid flow and pressure contour diagram leading up to the result, is this not possible with ANSYS Fluent?
      I would appreciate it if you could let me know.
    • Keyur Kanade
      This is possible in Fluent. Please define animation accordingly.
      Please check following videos.
      Regards Keyur
    • ESL
      Thanks for your comment!
      Thanks to this video, I was able to set up the animation I was looking for.
      Thank you for your guidance. I will use it in my research!
    • DrAmine
      Great!
Viewing 3 reply threads
