Discovery Import
Discovery Import
Display artifacts on shaded and enhanced s. display
    • luca
      What about this artifacts showing on enhanced shaded display?
      System Info gathered through Rhino7 SystemInfo
      Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
      Computer platform: DESKTOP
      Standard graphics configuration.
      Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
      >Accelerated graphics device with 4 adapter port(s)
      - Windows Main Display attached to adapter port #0
      - Secondary monitor attached to adapter port #1
      OpenGL Settings
      Safe mode: Off
      Use accelerated hardware modes: On
      Redraw scene when viewports are exposed: On
      Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
      Anti-alias mode: 4x
      Mip Map Filtering: Linear
      Anisotropic Filtering Mode: High
      Vendor Name: NVIDIA Corporation
      Render version: 4.6
      Shading Language: 4.60 NVIDIA
      Driver Date: 5-6-2021
      Driver Version: 27.21.14.6259
      Maximum Texture size: 32768 x 32768
      Z-Buffer depth: 24 bits
      Maximum Viewport size: 32768 x 32768
      Total Video Memory: 8 GB
    • Naresh Patre
      Hello Luca
      Sorry but I am not able to understand the problem. What does "artifact" refer to in the images that you have shared? Can you provide some detailed information? If possible, please share the model as well.
      • luca
        Naresh Patre  I mean that shadows or object highlight are showing moved or offset from actual object. If you look at images it is clearly visible. I found it to be not model related: sometime I resolve it just saving, quitting SC and reopening it. If you send an eMail or private link I will send a file next time I experience it. Thanks!
    • Naresh Patre
      Hello Luca
      Thanks for your reply. You can send the geometry to ansys-discovery-support@ansys.com.
