Display Contour Plot every 25 time-steps During Calculation
    • Mr_fixit16
      I feel like this should be simple, but i am having trouble finding a way to display a contour plot in Fluent at specified intervals of a calculation, say every 50 time-steps. I am performing a transient density based simulation of a pressure vessel and i would like to see a contour plot of velocity magnitude every 50 time-steps to see how the simulation is progressing.
      I believe the "execute commands" under calculation activities will do what i want, but i am not familiar enough with the TUI commands to write it. I have already set up a contour plot under the Results>Graphics>Contours GUI, but i am not sure how to show it during the simulation.
      In other words, is there a command to display a contour by the contour's name in the GUI?
      Capture
      Any advice or tips would be much appreciated! Thanks!
    • Karthik R
      Administrator
      After setting up your contours, say you want to display 'global-velocity-contour' as an image after every 25 iterations.
      You will first want to set-up a 'window-2' using the following TUI command: /display/open-window 2
      Click on 'Save/Display' contour and make sure that the contour plot shows up in 'Window 2'.
      Use the following TUI commands in 'Execute commands' window: /display/object/display global-velocity-contour
      Change 'every' to 25 and 'when' to 'iterations'.
      Please look at the attached images.
      Best Regards,
      Karthik
    • Mr_fixit16
      That did exactly what i was looking for, thank you very much!
      Do you know of anywhere online that explains the TUI commands and their syntax and how to use them? I found a list of commands in the user guide, but it does a poor job of explaining how to use them.
      Thanks again!
    • Karthik R
      Administrator
      Check out the ANSYS Fluent Text Command list for all the TUI commands and their usage.
      Best,
      Karthik
Viewing 3 reply threads
