March 23, 2021 at 10:57 am
dk89
SubscriberHi,nI am trying to display solid particle trajectories on a compressor rotor domain. I inject the particles from the inlet, which consists of 2183 cells. The particle tracking is completed, however my screen crashes every time when I try to display the particles. My PC screen crashes even for 100 particles. The Ram is 16 GB, so I believe it is adequate for these simulations. Do you have any suggestions on how can I fix the problem? Thank you.n -
March 23, 2021 at 1:29 pm
RK
Ansys EmployeeHello, nWhat is the particle track style you are using to display? Can you try with lines as the track style without continuous pulses?n -
March 23, 2021 at 1:38 pm
dk89
SubscriberHi, nThank you for your help. I forgot to mention that the particle tracking is steady-state and one-way coupling. I am trying to display lines as a track style and particle velocity magnitude. I press save/display, the particle tracking is completed, however my PC screen crashes and it doesn't display the trajectories. I also tried to skip some particles, but it didn't work. Any suggestions? Thank you.n -
March 23, 2021 at 2:25 pm
Ansys EmployeeCan you display contours etc?n -
March 23, 2021 at 2:36 pm
dk89
SubscriberYes, I can display air velocity contour for example.n -
March 23, 2021 at 3:49 pm
RK
Ansys EmployeeCan you please try the following : nLoad the case and data to a new fluent session and try to display the particles. nSetup a test case and check if you can display the particlesn -
March 24, 2021 at 8:41 am
Aitor
SubscriberIn previous versions of ANSYS Fluent, 3D arrows for vectors lead to computer crash (at least in my computer). In regards to particles, I seem to remember that the same problem occurred when displaying particles as spheresnWhich version of ANSYS Fluent are you using? Are you displaying particles as points?n -
March 24, 2021 at 9:51 am
dk89
SubscriberHi,nI tried to load the case and data to a new fluent session, but it didn't work. The sreen crashed again.n -
March 24, 2021 at 10:26 am
dk89
SubscriberI am using ANSYS 19.2. I am displaying the particles as lines. n -
March 24, 2021 at 10:49 am
Aitor
SubscriberCould you update Fluent version?n -
March 24, 2021 at 11:54 am
Ansys EmployeeCan you complete a particle track, ie track rather than display? That'll confirm it's graphics over something else. n -
March 24, 2021 at 12:44 pm
dk89
SubscriberYes, I can track particles without displaying them. The problem appears when I try to display them.n
Viewing 11 reply threads
Trending discussions
Top Contributors
2666
2120
1349
1132
461
Top Rated Tags
