Tagged: display, error, student-version, Windows-11, workbench
February 27, 2022 at 8:53 am
SoSp
SubscriberHello community,
I am facing a display error when I try to use workbench. Other Ansys applications seem to be displayed correctly. I noticed nothing special in the install log. It was no error log created.
Ansys cannot be found among the installed applications of windows and I get Api-errors with dll-files of Spaceclaim when I launch Workbench (event viewer applications of windows).
Event viewer log messages look like this:
System.IO.FileNotFoundException: Could not load file or assembly 'SpaceClaim.Api.V3.dll' or one of its dependencies. The system cannot find the path specified. File name: 'SpaceClaim.Api.V3.dll' ---> System.IO.DirectoryNotFoundException: The system cannot find the path specified. (Exception from HRESULT: 0x80070003) at System.Reflection.AssemblyName.nGetFileInformation(String s) at System.Reflection.AssemblyName.GetAssemblyName(String assemblyFile) at System.EnterpriseServices.Internal.AssemblyManager.InternalGetGacName(String fName)
Removal of an assembly from the global assembly cache failed: C:Program FilesANSYS IncANSYS Studentv221SCDMSpaceClaim.Api.V4SpaceClaim.Api.V4.dll
Please have a look at the attached screenshots and help me to find a solution.
March 2, 2022 at 1:07 pmGeorge Karnos
Ansys EmployeeIf 4K Display is being used , try the following:
1.Change the High DPI settings under compatibility settings." Properties of workbench > Compatibility > Click on Override high DPI scaling "
2. Change the "Scaling performed by" option to "System(Enhanced)"
March 2, 2022 at 3:25 pmSoSp
SubscriberI used the compatibility the troubleshooter of Windows 11 and it suggested to adjust DPI settings. It worked, so you were right either I guess.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2524
2066
1279
1096
457
