May 17, 2018 at 8:38 am
ybiran
SubscriberHi, I have a display issue on discovery spaceclaim in the drawing. When I want to create a note and add a symbol, I have a rectangular form but I can't see the symbol ! You can see the appearence of the problem with the image join ! I try to change the screen resolution but it does not solve the problem ! Best regards Yohann -
May 17, 2018 at 9:25 pm
Brian Bueno
Ansys EmployeeNOVACAD
Hi Yohann,
I have seen this before with standard SpaceClaim, but I don't remember exactly what the cause was.
Check the Windows fonts to see if anything is missing there. I will have to ask the development team about this.
You may want to try reinstalling the software using Run as Administrator.
July 4, 2018 at 7:35 am
July 4, 2018 at 8:32 am
ybiran
SubscriberWhere you can find these spaceclaim font and in witch folder I have to put them ?
Best Regards
Yohann
July 4, 2018 at 8:39 am
rg
SubscriberThese files are located within c / windows / font.
You have to click on it to install them, or right-click install admin (it would be better to do so) -
July 4, 2018 at 11:50 am
ybiran
SubscriberHi,
I don't find these files on this folders ! How to download this ?
July 4, 2018 at 1:24 pm
rg
SubscriberIf you want I can send them to you, copy them to the file path I told you REGARDS🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
3850
2629
1853
1246
600
