March 9, 2022 at 11:15 am
thomas
SubscriberIs it still necessary to install version 4xx.xx for us still having this issue? Or do you have another quick fix for this ? (option 1 and 2 did not work for me as I've had version 5 a long time already..)
March 9, 2022 at 4:10 pm
Subashni Ravichandran
Forum ModeratorHello Thomas Jacobsen
If I understand correctly, disable the intel GPU from the BIOS also does not work for you with Refine display issue and going back on the graphics version is not an option. Is that correct?
Can you please share a screenshot of the graphics issue you are facing in Refine mode?
Also, can you please specify which version of Discovery you are using?
March 11, 2022 at 7:12 am
thomas
SubscriberI've downgraded nvidia drivers to 472.98 and did a clean install with that, and it resolved the problem with red dots in refine mode. But I am still having issues that when simulating particals. Explore mode is 100 times better then refine (even when both are set to highest fidelity). Refine mode only shows a few particals compared to explore mode where you can see thousands of particals..
March 11, 2022 at 10:02 am
I believe number of particles generated increase with element count. Can you try increasing the mesh count to see if this improves your particle result display?
We thank you for sharing your feedback. We will share your idea/input with the product development team.
March 11, 2022 at 10:17 am
thomas
SubscriberSubashini, can you send me an e-mail so I can send you some videos of this issue
March 11, 2022 at 10:36 am
You can send you video with the issue to ansys-discovery-support@ansys.com.
Please remember to refer to this query in the email for reference.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2957
1449
1322
