display mesh and hide another mesh
    • manelaero2020
      Hi friends;
      I am meshing a wing of an aircraft inside its fluid domain. I have done the mesh (in Ansys Meshing), all the bodies have BEEN meshed. I want to see my mesh only on the wall of the wing, I have hidden the inlet and outlet of the fluid domain, but when I click on the wing, all fluid domain is displayed another time, and I fail to see what is happening only at the walls of the wing.
      Have you some idea (or video) about how to do this, please?
      tHANK YOU VERY MUCH
      best regards
    • Emperor
      Maybe you can try a cutaway of your domain to see what's on the boundary layer. I think this could be a solution,
      to do this: click on manage and then on flat section, you can then draw a line on the section plane you want, a quick example below:
      I hope this helps
    • Karthik R
      Administrator
      Hello Quick comment: The Section Plane is also available in the 'Insert' tab.
      Karthik
    • MMary
      Create a named selection of your fluid domain, just like you did with the inlet and outlet, then right click 'hide'.
    • manelaero2020
      Thank you freinds ok
Viewing 4 reply threads
