Display results on multiple planes from Fluent run
    • jeyaraj
      I am using Ansys Fluent for the set up and calculation run; How to view the results of properties such as; velocity x,y,z, volume fraction of fluid, density etc, in the following pattern:
      1)In series vertical planes
      2) series of horizontal planes
      3) for different flow time
    • raul.raghav
      You can do all these in CFD-Post easily. Refer to the attached pictures if you haven't used CFD-Post before.
      Creating a Slice Plane
