Display the contour lines on the efficiency maps Using Machine toolkit
    • hkanakri
      Hello All,
      I need to display the contour lines on the efficiency maps with the efficiency values Using Machine toolkit, to produce a map similar to the one below. Any suggestions how to do it?
    • Deyu Li
      double click on the color legend and the property window will pop up:
      In contour tab, check overlay contour lines and show labels boxes.
    • hkanakri
      Hello Deli,
      This is great, and solved the issue. Thank you so much!
      -Haitham
    • phuonganhlovely.me
      Hello guys I am using EDT to simulate an axial flux motor (3D model), and now I want to plot the efficiency map using a machine toolkit.
      The question is when I finished simulating the machine toolkit how can i plot efficiency map, current and voltage plots, output power.... same figure above?
      can you provide screenshots of your Machine toolkit setup and preprocessing steps ( i mean the explanation of each pages of Machine toolkit setup) or where can i get information to do it ?( i have read Maxwell ACT Extensions Wizards in PDF file and still vague about it)
      it is perfectly if you can help
      Thanks in advance
Viewing 3 reply threads
