Dissolved NaCl
    • AhmedCfx
      Hi all
      I’d like to ask you, how to simulate dissolved salt in water and check the density and viscosity for different temperatures?
      Best regards
      If it's already dissolved and there is no change in concentration within the domain you supply the density & viscosity.  If you're mixing two fluids then you define the values for each fluid and set a mixture where the mixture will take account of the two (or more) fluids.
      Note, properties can be a function of temperature. If it boils you'll need additional models too.
    • AhmedCfx
      Dear rwoolhou
      I need to change the concentration of salt several times and check the density and viscosity of the mixture. I need to make it miscible process .
      You're dissolving more salt?  The solver uses user supplied materials data to determine density & viscosity so you will need to explain exactly what you want to show and find out before we can advise.
    • AhmedCfx
      Dear rwoolhou
      in Hysys software you can mix salt and water in room temperature to get a new solution and you add different volume fraction of salt and each time calculates the density and viscosity of the solution, my question is , does Ansys has the same ability ? I think it is something chemical instead of CFD.
      Hysys probably has a built in materials model to handle that. In CFD codes we can model this sort of application (rather than assuming mixing rates & efficiencies) but you'd need to input those material properties yourself.
      Aspen & CFD have different uses. I'd use the former to design a chemical process plant and CFD to optimise the individual pieces of equipment.
Viewing 5 reply threads
