Preprocessing
Preprocessing
Distorted mesh generation
    • nineone
      I am working on generating a mesh of a UAV but the mesh appears weirdly distorted in certain places. Last time I saw this it was solved by messing with the scoped sizing but this time that doesn't work. Any ideas on how to deal with this would be appreciated. Thank you!
    • peteroznewman
      Please insert an image of the mesh.
    • nineone
      That looks like the surface is missing or corrupted somehow.  How does it look without the mesh and in the geometry tool?
    • nineone
      Here it is in the geometry tool.
    • Keyur Kanade
      The image looks like from Fluent Meshing.
      Can you please open geometry in SpaceClaim?
      Then use Split option to split faces of fuselage and then proceed to Fluent Meshing.
      Keyur
Viewing 5 reply threads
