August 21, 2023 at 6:46 pm
Ziqi Liu
SubscriberHi everyone,
I am attempting to run Ansys HFSS on the Scinet supercomputer, which comprises 4 nodes, each equipped with 40 cores available for running Slurm jobs. My goal is to simulate a large domain, leveraging HFSS's domain decomposition feature, which allows simultaneous solving of different domains on separate nodes. I intend to split the simulation into 4 tasks and distribute them across the nodes. While I am familiar with distributing tasks on a single node, I am unsure about the process for distributing tasks across multiple nodes.
Below is the code I am currently using. To submit the Slurm job, I use the command "sbatch sample.sh". Could someone kindly assist me with this? I am uncertain where I might have made a mistake.
It gives me error:
August 25, 2023 at 2:45 pm
randyk
Ansys EmployeeHi Ziqi,
What is the OS version: cat /etc/*release
What is the SLURM version: sinfo -V
Note that AnsysEM2021R2 was the first release to officially support SLURM. There were a few bugs/workarounds needed. I would consider migrating to a current version AEDT.
Here are my notes regarding AEDT2021R2 on SLURM
If you get a case with AEDT2021R2 and SLURM 20.x - run through this first.Important, customer must be running AEDT 2021R2 and SLURM 20.x for the following steps-- You would want to gather the following to confirm scheduler version and network info$ cat /etc/*release$ sinfo -V$ ifconfigEnabling tight integration change - this requires editing slurm_srun_wrapper.sh and setting batchoption 'RemoteSpawncommand'1.. (TFS447753) edit the slurm_srun_wrapper.sharchive/copy .../AnsysEM21.2/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh to slurm_srun_wrapper.sh.ORIGedit .../AnsysEM21.2/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh and insert the following at line 28: host=$(echo "${host}" | cut -d'.' -f1)ex:if [[ -n "$ANSYSEM_SLURM_JOB_ID" ]]thenexport SLURM_JOB_ID="${ANSYSEM_SLURM_JOB_ID}"echo "set SLURM_JOB_ID=${SLURM_JOB_ID}" >> "$DEBUG_FILE"fi=> # tfs447753=> host=$(echo "${host}" | cut -d'.' -f1)verStr=scontrol --version
2.. (TFS554680) If SLURM version 20.0-20.10 - Generic SLURM scheduler integration does not check for SLURM minor versionsrun '--overlap' option was introduced in SLURM VERSION 20.11slurm_srun_wrapper.sh only checks if the version is >= 20 and attempts to apply the srun '--overlap' optionedit .../AnsysEM21.2/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh and comment out the appropriate srun and if/else/fi lines at bottom of file# if [ "${ver[0]}" -ge 20 ];then # SLURM ver >= 20.**.**# echo "srun --overcommit --overlap --export=ALL -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 -w ${host} $@" >> "$DEBUG_FILE"# srun --overcommit --overlap --export=ALL -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 -w $host "$@"# elseecho "srun --overcommit --export=ALL -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 -w ${host} $@" >> "$DEBUG_FILE"srun --overcommit --export=ALL -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 -w $host "$@"# fiThis should enable customer to run manual jobs for adaptive meshing, and then auto jobs for frequency sweeps.3.. After making the slurm_srun_wrapper.sh file change, run the following to set defaults to tight integration (will create/modify //AnsysEM21.2/Linux64/config/default.XML) as root or installation ownercd /opt/AnsysEM/AnsysEM21.2/Linux64./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Desktop/Settings/ProjectOptions/ProductImprovementOptStatus" -RegistryValue 0 -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS 3D Layout Design/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 2D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 3D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Q3D Extractor/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Icepak/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS 3D Layout Design/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 3D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 2D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Q3D Extractor/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Icepak/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Desktop/Settings/ProjectOptions/ProductImprovementOptStatus" -RegistryValue 0 -RegistryLevel install# ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Desktop/Settings/ProjectOptions/AnsysEMPreferredSubnetAddress" -RegistryValue "192.168.1.0/24" -RegistryLevel install4.. An example batch script:Create %HOME/anstest/job.sh with the following contents (correct highlighted):#!/bin/bash#SBATCH -N 3 # allocate 3 nodes#SBATCH -n 12 # 12 tasks total##SBATCH --exclusive # no other jobs on the nodes while job is running#SBATCH -J AnsysEMTest # sensible name for the job#Set job folder, scratch folder, project, and design (Design is optional)JobFolder=$(pwd)ProjName=OptimTee-DiscreteSweep-FineMesh.aedtDsnName="TeeModel:Nominal"# Executable path and SLURM custom integration variablesAppFolder=/opt/AnsysEM/AnsysEM21.2/Linux64# setup environment and srunexport ANSYSEM_GENERIC_MPI_WRAPPER=${AppFolder}/schedulers/scripts/utils/slurm_srun_wrapper.shexport ANSYSEM_COMMON_PREFIX=${AppFolder}/commonexport ANSYSEM_TASKS_PER_NODE=${SLURM_TASKS_PER_NODE}# setup srunsrun_cmd="srun --overcommit --export=ALL -n 1 --cpu-bind=none --mem-per-cpu=0 --overlap "# note: srun '--overlap' option was introduced in SLURM VERSION 20.11"# MPI timeout set to 30min default for cloud suggest lower to 120 or 240 seconds for onpremexport MPI_TIMEOUT_SECONDS=120# System networking environment variables - HPC system dependent should not be user edits!# export ANSOFT_MPI_INTERCONNECT=ib# export ANSOFT_MPI_INTERCONNECT_VARIANT=ofed# Skip dependency check# export ANS_NODEPCHECK=1# Autocompute total cores from node allocationCoreCount=$((SLURM_JOB_NUM_NODES * SLURM_CPUS_ON_NODE))# Run Job${srun_cmd} ${AppFolder}/ansysedt -ng -monitor -waitforlicense -useelectronicsppe=1 -distributed -auto -machinelist numcores=$CoreCount -batchoptions "" -batchsolve ${DsnName} ${JobFolder}/${ProjName}Then run it:$ dos2unix $HOME/anstest/job.sh$ chmod +x $HOME/anstest/job.sh$ sbatch $HOME/anstest/job.shWhen complete, send resulting:$HOME/anstest/OptimTee-DiscreteSweep-FineMesh.aedt.batchinfo/*.log5. If customer using Windows to Linux submissionAnsoftrsmservice cannot run as root.-- make sure to set ANSYSEM_GENERIC_EXEC_PATH before starting ansoftrsmservice-- In ansoftrsmservice.cfg, the content should be:$begin 'Scheduler''SchedulerName'='generic''ConfigString'='{"Proxy":"slurm", "Data":""}'$end 'Scheduler' -
August 25, 2023 at 2:48 pm
randyk
As indicated many SLURM integration issues were resolved by the 2022R2 release.
If you are able to migrate to AnsysEM2022R2 or newer, the following guidance should help.If you get a case with AEDT2022R2 and SLURM 20.x - run through this first.Important, customer must be running AEDT 2021R2 and SLURM 20.x for the following steps-- You would want to gather the following to confirm scheduler version and network info$ cat /etc/*release$ sinfo -V$ ifconfigEnabling tight integration change - this requires setting batchoption 'RemoteSpawncommand'1.. run the following to set defaults to tight integration (will create/modify //v222/Linux64/config/default.XML) as root or installation ownercd //v222/Linux64 ./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Desktop/Settings/ProjectOptions/ProductImprovementOptStatus" -RegistryValue 0 -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "HFSS/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "HFSS 3D Layout Design/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Maxwell 2D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Maxwell 3D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Q3D Extractor/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Icepak/MPIVendor" -RegistryValue "Intel" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "HFSS/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "HFSS 3D Layout Design/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Maxwell 3D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Maxwell 2D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Q3D Extractor/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Icepak/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Desktop/Settings/ProjectOptions/ProductImprovementOptStatus" -RegistryValue 0 -RegistryLevel install# ./UpdateRegistry -set -ProductName ElectronicsDesktop2022.2 -RegistryKey "Desktop/Settings/ProjectOptions/AnsysEMPreferredSubnetAddress" -RegistryValue "192.168.1.0/24" -RegistryLevel install2.. An example batch script:Create %HOME/anstest/job.sh with the following contents (correct highlighted):#!/bin/bash#SBATCH -N 3 # allocate 3 nodes#SBATCH -n 12 # 12 tasks total##SBATCH --exclusive # no other jobs on the nodes while job is running#SBATCH -J AnsysEMTest # sensible name for the job#Set job folder, scratch folder, project, and design (Design is optional)JobFolder=$(pwd)ProjName=OptimTee-DiscreteSweep-FineMesh.aedtDsnName="TeeModel:Nominal"# Executable path and SLURM custom integration variablesAppFolder=//AnsysEM/v222/Linux64 # setup environment and srunexport ANSYSEM_GENERIC_MPI_WRAPPER=${AppFolder}/schedulers/scripts/utils/slurm_srun_wrapper.shexport ANSYSEM_COMMON_PREFIX=${AppFolder}/commonexport ANSYSEM_TASKS_PER_NODE=${SLURM_TASKS_PER_NODE}# setup srunsrun_cmd="srun --overcommit --export=ALL -n 1 --cpu-bind=none --mem-per-cpu=0 --overlap "# note: srun '--overlap' option was introduced in SLURM VERSION 20.11"# MPI timeout set to 30min default for cloud suggest lower to 120 or 240 seconds for onpremexport MPI_TIMEOUT_SECONDS=120# System networking environment variables - HPC system dependent should not be user edits!# export ANSOFT_MPI_INTERCONNECT=ib# export ANSOFT_MPI_INTERCONNECT_VARIANT=ofed# Skip dependency check# export ANS_NODEPCHECK=1# Autocompute total cores from node allocationCoreCount=$((SLURM_JOB_NUM_NODES * SLURM_CPUS_ON_NODE))# Copy Example to $JobFoldercp ${AppFolder}/schedulers/diagnostics/Projects/HFSS/${ProjName} ${JobFolder}/${ProjName}# Run Job${srun_cmd} ${AppFolder}/ansysedt -ng -monitor -waitforlicense -useelectronicsppe=1 -distributed -auto -machinelist numcores=$CoreCount -batchoptions "" -batchsolve ${DsnName} ${JobFolder}/${ProjName}Then run it:$ dos2unix $HOME/anstest/job.sh$ chmod +x $HOME/anstest/job.sh$ sbatch $HOME/anstest/job.shWhen complete, send resulting:$HOME/anstest/OptimTee-DiscreteSweep-FineMesh.aedt.batchinfo/*.log================================================If customer using Windows to Linux submission================================================1.. Ansoftrsmservice cannot run as root.-- make sure to set ANSYSEM_GENERIC_EXEC_PATH before starting ansoftrsmserviceedit: /path/rsm/Linux64/ansoftrsmservice and add line 2:export ANSYSEM_GENERIC_EXEC_PATH=//v222/Linux64/common/mono/Linux64/bin:/ /v222/Linux64/common/IronPython 2.. Patch slurm_srun_wrapper.shFile: //AnsysEM/rsm/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh Replace line 20slurm_host=$(${mono} ${ipy} ${script} --replacehost ${host})with:slurm_host=$(echo "${host}" | cut -d'.' -f1)3..-- In ansoftrsmservice.cfg, the content should be:$begin 'Scheduler''SchedulerName'='generic''ConfigString'='{"Proxy":"slurm", "Data":""}'$end 'Scheduler'
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2959
1449
1322
