February 10, 2021 at 10:22 am
ciema
SubscriberHello, I cannot run calculations in very simple model in ANSYS 18.2 mechanical, when distributed option is checked. SMP mode works correctly, when DMP is used (no Solver Output file is generated, calculations are stopped on Preparing Mathematical Model). The same situation is on Direct and Iterative Solver. Does anyone have suggestions?n -
February 11, 2021 at 3:16 pm
George Karnos
Ansys EmployeeHello Ciema,nDo you have a firewall enabled?nCan you try shutting it down and then try to run distributed?nAlso, are you connected to VPN when running?nBest,nGeon -
February 15, 2021 at 9:53 am
ciema
SubscriberThanks for reply! The problem was with Network Card ID for docking station. When docking station was not used, the problem disappeared. nMany thanks for help.n
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5370
3363
2471
1310
1020
