August 26, 2019 at 1:36 pm
rohandixit1987
SubscriberHello,
I would like to do Modal Analysis of a component in ANSYS DIscovery AIM. However, I got following error -
*** ERROR *** CP = 222.266 TIME= 18:54:05
There is not enough memory for the Distributed Sparse Matrix Solver to
proceed using the out-of-core memory mode. The total memory required
by all processes = 51056 MB. The total physical memory that is
available on the system = 29030 MB. Please decrease the model size,
or run this model on another system with more physical memory.*** ERROR *** CP = 222.266 TIME= 18:54:05
Distributed Sparse Matrix Solver failure. Please check the error file
for possible causes.*** ERROR *** CP = 222.281 TIME= 18:54:05
An error occured inside DSP solver
Call to DSP Routine dsp_allocFinalMem failed (info=4).*** ERROR *** CP = 225.000 TIME= 18:54:15
for possible causes.*** ERROR *** CP = 225.000 TIME= 18:54:15
Call to DSP Routine dsp_allocFinalMem failed (info=4).Please refer attached herewith error files for the same.
Request to provide a solution for the same.
Thanks & Regards,
RD
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
August 26, 2019 at 5:07 pm
Gaurav Sharma
SubscriberHi RD
How many nodes are there in your meshed model.
The computational requirement to solve a problem in Discovery AIM is directly dependent on the number of nodes in your model. The error message indicates that the problem you are working on is more complex than what the hardware in use can handle.
For most of the cases, this is triggered by the use of extremely fine elements to mesh the model. Reducing the mesh count by using relatively coarser elements, should help you do away the problem.
Also, please let me know the configuration of the machine you are using (RAM and available disc space on the drive where model is saved).
Thanks & Regards,
Gaurav
August 27, 2019 at 5:06 pm
rohandixit1987
SubscriberHello Gaurav_ANSYS
I reduced the mesh size from 0.001 to 0.01. With this, I was able to make a run.
I think, this has helped to reduce the no. of nodes.
Thank you for your help.
RD
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3648
2512
1739
1226
578
