November 19, 2023 at 2:54 pm
jasonsum25
SubscriberHi, I am simulating the wind flowing across a Y-shape building to evaulate the wake effect behind.
Mesh was done in Fluent Meshing, with minimum orthogonality of 0.2, and 5 inflation laters added to ground and building surface.
with BOI refinement in volume near the building
To be more accurate towards reality, I want to take the atmospheroc boundry layer for the wind flow inlet condition.
However, divergence and float points popped up on console when initiaizing. (while just using constant input to inlet velocity did not cause such issues), it is earnestly hoped for some guidance on this and some additional tips on using UDF, thanks!!!!
Error codes:
Divergence detected in AMG solver: ads-0
Divergence detected in AMG solver: ads-0 10 0.000000e+00
Hybrid initialization is done.
Error at host: floating point exception
Error at Node 4: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error at Node 5: floating point exception
Error at Node 6: floating point exception
Error at Node 7: floating point exception
Error at Node 8: floating point exception
Error at Node 9: floating point exception
Error at Node 10: floating point exception
Error at Node 11: floating point exception
Error at Node 12: floating point exception
Error at Node 13: floating point exception
Error at Node 14: floating point exception
Error at Node 15: floating point exception
Error at Node 16: floating point exception
Error at Node 17: floating point exception
Error at Node 18: floating point exception
Error at Node 19: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
Below is the UDF I taken reference from &t=2395s:
#include "udf.h" #define UREF 4.491 // reference wind speed at ZREF #define ZREF 0.16 // height of the building, 2b #define LREF 0.08 // characteristic length, b #define CMU 0.09 // DEFINE_PROFILE(velocity_profile, thread, position) { float x[ND_ND]; float y; float u; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y=x[1]; u = UREF*pow(y/ZREF,0.27); F_PROFILE(f,thread,position) = u; } end_f_loop(f, thread) } /* profile for kinetic energy, k */ DEFINE_PROFILE(k_profile, thread, position) { float x[ND_ND]; face_t f; float A1 = 0.0042 ; float A2 = -0.0719 ; float A3 = 0.2692 ; float A4 = 0.3671 ; float k, y, yb; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; yb = y/LREF; k = A1*pow(yb,3)+A2*pow(yb,2)+A3*yb+A4 ; F_PROFILE(f,thread,position)=k; } end_f_loop(f, thread) } /* profile for dissipation rate, epsilon */ DEFINE_PROFILE(dissip_profile, thread, position) { float x[ND_ND]; face_t f; float A1 = 0.0042 ; float A2 = -0.0719 ; float A3 = 0.2692 ; float A4 = 0.3671 ; float k, y, yb; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y=x[1]; yb = y/LREF; k = A1*pow(yb,3)+A2*pow(yb,2)+A3*yb+A4 ; F_PROFILE(f,thread,position)=pow(CMU,0.75)*pow(k,1.5)/LREF; } end_f_loop(f,thread) } /* References: [1] Yan MENG and Kazuki HIBI. Turbulent measurements of the flow field around a high-rise building. Journal of wind engineering. No 76, July 1998. */
November 20, 2023 at 12:31 pm
Forum ModeratorYou may want to check your direction vector for "up". If z is up it's not [1] in the vector definition!
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1474
