“Divergence detected for field Carbondioxide: iterations cancelled by Expert System”
    • uxsarah
      I am doing a mold filling of a chemical reaction flow, but the error "Divergence detected for field Carbondioxide: iterations cancelled by Expert System " occured.
      How can solve the divergence problem? I tried to generate a fine mesh of the model, but it was not working.
      Many thanks.
    • uxsarah
      The fllowing is a part of the listFile. Can someone please give me some advices, many thanks.
       *     VOF     *
       Running vof for T within [ 0.000E+00 , 2.000E+02 ]
        with dT-ini = 1.000E-01,
             dT-min = 1.000E-02, dT-max = 2.500E-01,
        with up to 2000 successful steps,
        ===> Starting VOF
               at T-ini = 0.000E+00
            Initial volume     =  1.4103619E-04 / 4.1392274E-02
       Preprocessors
       Convergence assumed : Rel. var. LT  1.00000E-04
       F.E.M. Task
       Global divergence has occured. Diverg =  0.2000000E+04
          VOF Step #1                                 |   Progress bar(s)  |
            Time               =  0.0000000E+00       |>                   |
            Volume of fluid    =  1.4103619E-04       |>                   |
            Volume filled (%)  =  3.4073070E-01       |>                   |
            Step status : KO
                Solver divergence occured.
               New time step      =  5.0000000E-02
       Preprocessors
       F.E.M. Task
      Divergence detected for field Urethane: iterations cancelled by Expert System
            Step status : KO
               New time step      =  2.5000000E-02
    • uxsarah
      Modify the convergence test =2.00000E-3
      Modify the divergence test = 2.00000E+4
      Modify the convergence test for species = 5.000000E-3
      Modify the solver aggressivity =2 (very robust)
      ===> solver type=AMF direct solver
      Is there anything wrong with the setting?
