August 8, 2019 at 12:40 pm
snr1
SubscriberDear sir, i am simulating the absorption process in Fluent 18.1. The geometry is as follows.
I am using steady state solver with Eulerain Implicit model and species transport model (spcies mass transfer model). As the run calculation is started, immediately it is diverging and giving floating point exception. How to get resolve this issue. The error is shown below.
August 8, 2019 at 1:46 pm
Ansys EmployeeTry with transient: what flow regime are you expecting?
August 8, 2019 at 3:25 pm
DrAmine
Ansys EmployeeTo add: if possible use actual versions. -
August 8, 2019 at 3:48 pm
snr1
SubscriberBubbly flow sir
August 8, 2019 at 3:50 pm
snr1
SubscriberWhat actual versions mean? I didn't get sir. Can you elaborate it further?
August 8, 2019 at 4:00 pm
DrAmine
Ansys EmployeeFLUENT version.
Can you add details about phase interaction? -
August 8, 2019 at 6:34 pm
snr1
Subscriberphase interaction:
1. virtual mass: Default
2. Drag: schiller-Naumann
3. Lift, wall lubrication, Turbulent dispersion, and Heat: None
4. Mass: Species mass transfer model
5. Reactions: none
6. Surface tension: constant
7. Interfacial area: ia-symmetric
August 8, 2019 at 7:49 pm
DrAmine
Ansys EmployeeDisable all forces keep drag. Screenshot of mass transfer panel. -
August 8, 2019 at 8:10 pm
August 8, 2019 at 8:14 pm
DrAmine
Ansys EmployeeMake mass transfer from liquid solution to gas and adjust resistances accordingly. -
August 8, 2019 at 8:15 pm
snr1
SubscriberYes sir i have tried that also, but has resulted the same.
August 9, 2019 at 5:53 am
DrAmine
Ansys EmployeeWhat about assuming a resistance on the bubble sides instead of zero-resistance, does it help?
Can you try with newer version?
DrAmine
Ansys EmployeeDoes it run without mass transfer?
August 9, 2019 at 6:30 am
snr1
SubscriberWith out mass transfer it works fine
August 9, 2019 at 6:41 am
DrAmine
Ansys EmployeeThat confirms that I was thinking.
1/Try transient with small time step size
2/Please try to run with actual release and let us know.
August 9, 2019 at 6:46 am
snr1
SubscriberDear sir, what excatly means actual release?
Time steps i have tried are: 1e-4 anf 1e-6. But still results same
August 9, 2019 at 9:26 am
DrAmine
Ansys EmployeeI am referring to using Fluent 2019R2.
2630
2104
1329
1110
461
