August 8, 2019 at 3:22 pm
rachels1001
SubscriberHey guys,
I have a simulation modelling air flow over a series of pellets of different size. I wanted to model the flow using axisymmetry, with the center of the pellets being along the axis of symmetry (pictured below).
I have a mass-flow inlet at the top of the 2D geometry and a pressure outlet at the bottom. The non-pellet side of the mesh is designated as an adiabatic wall, and the pellet side of the mesh is a symmetry plane. I initially ran the simulation using the 2D planar setting (incorrectly, had forgotten to make the adjustment) and the simulation was able to run and converge. However, when I switched over to the 2D axisymmetric setting, the simulation was able to initialize; however, I got the error that there was a "divergence in the AMG solver: x-momentum" as soon as it began iterations. This error appeared immediately, before the simulation had completed any iterations.
I tried changing the mass-flow inlet to a velocity-inlet to address the problem; however the same thing occurred. Are there any large changes you have to make to your boundary conditions when you move from 2D planar to 2D axisymmetric?
August 8, 2019 at 3:39 pm
DrAmine
Ansys EmployeeCan you show the outline of the model. Is flow axisymmetric? Have a defined the x axis to be the symmetry axis? -
August 8, 2019 at 5:18 pm
August 8, 2019 at 5:29 pm
August 8, 2019 at 7:41 pm
DrAmine
Ansys EmployeeHas to be the x-axis. -
February 24, 2020 at 1:42 pm
Chaymae
SubscriberHi
I am facing the same problem though I am using the x-axis.
Regards
2706
2146
1357
1144
462
