January 8, 2018 at 10:55 am
yangyee
SubscriberWhen I use CFX to simulate the flow field of a compressor cascade. Sometimes I may encounter a problem: In the OUT-file, there is a notation "The maximum Mach number is very large(such as 3000, etc.)". Can someone tell me the reason? Thank you!!!
January 8, 2018 at 11:07 am
Raef.Kobeissi
SubscriberHello yangyee,
It could be a multitude of issues. Could you attach the geometry or mesh to check . We need more info about the simulation to help you more.
Cheers
January 10, 2018 at 7:24 am
Min Zhang
SubscriberMay be you can try to modify the TimeScale value (In "Solver-Control" option).
In addition, since the flow endures strong adverse pressure gradient in the compressor cascade, you can perform a simulation by specifying a small outlet pressure and use it as the initial value for your actual case.
January 10, 2018 at 10:33 am
yangyee
SubscriberThanks for your suggestion! Min Zhang
2616
2098
1323
1108
461
