August 29, 2022 at 2:19 pm
walidelsiwi
SubscriberI am about to submit a paper that i have been working on for a while. I used some default materials properties that are available in ANSYS workbench materials library. these properties has already been published in journal back in 2001.and it is clearly referenced in ANSYS material library as well as in my paper.
Please I need help...
August 30, 2022 at 3:08 pm
Vishal Ganore
Ansys EmployeeSpecial permission is not required. Make sure to add a reference to a material library in your paper.
August 31, 2022 at 10:07 am
David Mercier
Ansys EmployeeHi, here everything you should know about citing Ansys when you write a paper.
https://www.ansys.com/academic/terms-and-conditions
and here a post about this question and Granta products: https://forum.ansys.com/forums/topic/can-i-use-granta-edupack-for-research-publications/
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2642
2110
1335
1112
461
