Tagged: 2-way-coupled-fsi, 2-way-fsi, aircraft, earth-gravity, gravity
March 21, 2022 at 10:50 am
El_Manguangua
SubscriberHey, I hope you are all doing great, just as the title says, I was wondering, within the context of a Fluid-Structure Interaction (FSI) simulation in ANSYS, if I need to consider the weight of the aircraft as well as the weight of the air while they're interacting. I've seen people neglecting these effects and I've been told by other people that I should neglect these effects myself.
In the case of air, I actually get it, since it has low density, it may actually not have an important effect, but in the wing structure case, I just do not see why self-weight should be neglected since there is some "static deformation" given exclusively by this static force, what do you say?
I get that adding gravity effects may enlarge simulation time, but isn't it worth it?
March 22, 2022 at 2:14 pmAshish Khemka
You can consider gravity effects for the sake of completeness. You can even load the structure under self-weight and the use the deformed shape in future analysis.
Regards Ashish Khemka
2564
2078
1291
1106
459
