April 16, 2021 at 12:46 pm
dcl
SubscriberHello,nI'm working with CADNexus to import a CATPart file with parameters created on CATIA V5 to SpaceClaim. I'm trying to run many CFD simulations with parameters on my geometry in order to obtain a response surface. nThe probem is that after my first calculation is done (on the geometry with initial parameters) all the other design points apparently update the geometry and the meshing well but after solving with fluent I got the exact same result for every design points.nTo make sure the geometry was really updated every time, I tried with absurd values (like a thickness equal to 0) but DesignXplorer surprisingly does not seem to face any issue although this update is obviously impossible on CATIA. So I'm not even sure that new geometries are created and I am afraid that only the initial geometry is used.nI'm using Ansys 2019 R3nI'll be glad if anyone can help.n
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Optislang workbench add-in
- Parameter relationships for Optimization
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- Errors about integrate executable into ANSYS Workbench using ACT
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3678
2552
1751
1232
584
