Process Integration and Design Optimization
DOE all parameters fail to updated in geometry
    • dcl
      Hello,nI'm trying to set up a CFD optimisation with DesignXplorer. I'm using CADNexus to import a CATPart file with parameters created on CATIA V5 to SpaceClaim. I manage to make a calculation for the initial geometry with initial parameters' values.nTo obtain a response surface, for every design points Design Xplorer is supposed to update the geometry with curent parameters' values, set the mesh and then solve with fluent. But somehow the parameters fail to update for every design points, the error message is Parameters failed to update in geometry without any other precision. I have been trying to find out what was wrong with my setup but for me everything seem t be ok.ni'm sure the problem is not comming from my CATPart file because I used the same weeks ago in a similar study and everything went well. nI'm using Ansys 2019 R3nI'll be glad if anyone can help.
Viewing 0 reply threads
