Ansys Free Student Software
DOE does not update output parameters
    • glipkowitz
      All of my results simply give the same output parameter as my design currently in the workbench. My input parameter is the radius of a cylinder. I am using student version. Is student version unable to run parametric studies?
    • peteroznewman
      The Student version is able to run Parametric studies. You're just making a mistake that needs to be corrected.
    • glipkowitz
      Would you have any ideas why that'd be the case?
