Does Ansys-Aim allow data exportation from a plotted 3D vector field?
    • kdai
      In a recent electromagnetic project in Ansys Aim 18.2, I was trying to simulate the magnetic field around certain setup of wires. I was able to plot the 3D vector field of magnetization following the tutorials. However, I also need to do further analysis besides visualization. It is better if I can obtain the component values of H at each point in space (i.e. those data used to plot the 3D graph) and export them as csv files. Is this a feature supported by Ansys Aim? Could anyone direct me to a relevant tutorial?
      Thank you.
    • ploped00
      I have the same requirement. Did you finally solve it?
      Thanks
    • Vishal Ganore
      The solution is here.
      https://forum.ansys.com/forums/topic/export-data-from-ansys-aim/
