October 3, 2018 at 12:38 am
xuehewang
SubscriberAs titled.
My plan is to check how good the communication is between two antennas(One as the transmitter while the other as the receiver), but when I put them inside a same airbox and simulated them, I don't know how to plot the field between them and how to set one a receiver and the other as the transmitter.
Could somebody help me with it plz?
October 3, 2018 at 2:04 am
asamaiyar
SubscriberHi xuehewang,
You can modify sources as shown in figure below (HFSS > Fields > Edit Sources...):
In above example, Port #1 is OFF (or just receiving) and Port #2 is ON (transmitting). Now you can plot the fields between them.
I would also recommend using separate FE-BI on Tx and Rx instead of one huge airbox. Ansys has tools like Savant or EMIT which may be much better for multiple Tx and Rx placed far away from each other.
Hope this helped!
Thanks,
AS
October 3, 2018 at 2:14 am
xuehewang
SubscriberThanks a lot
November 8, 2018 at 6:38 pm
Isadora
SubscriberHi asamaiyar,
I have the same question. But how to deal with the air between those boxes? All the boundaries needs to be set are just two FE-BI boundaries? When I use two FE-BI boxes, dose the simulator consider the distance between them, or no matter what distance, they are considered as far field?
Thank you so much!
March 24, 2019 at 10:22 am
Manu007
Did u get the results ?,after modifing the ports as suggested.
And were the S12 and S21 plots similar
March 25, 2019 at 5:47 pm
Peter Serano
Ansys Employee@Isadora - when you use FE-BI boundaries HFSS calculates the interactions between the surface currents on the two boxes and takes the distance into account using Green's Functions...
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
