Does anyone know what to do when “Plasticity algorithm did not converge for element xxx” appears?
    • jbraido
      Hi everybody,I'm modeling a T concrete beam to define crack regions. In Ansys, I modeled only half beam and forces were applied as a 4 point bending test.nBoundary conditions avoid displacements in vertical, longitudinal and transversal directions.nI'm using SOLID65 and REINF265.nAnsys closes during analysis and the message Plasticity algorithm did not converge for element xxx appears.nI'll appreciate it if someone could give me more information about it.n
    • Ashish Khemka
      nnThis message is displayed when Ansys is not able to converge plastic deformation increment. This generally occurs when the load is rapidly applied. I would suggest you to apply load more slowly by increasing number of substeps using NSUBST command. // Command Reference // XV. N Commands // NSUBST.nnRegards,nAshish Khemkan
    • jbraido
      @akhemka thank you for your answer! Really helped me!n
    • Erik Kostson
      Solid65 are old legacy elements that can be mesh sensitive giving inaccurate results.nnWe recommend using solid186 and reinf elements for reinforced concrete.nThey are also very well behaved and converge well even past concrete failure.nnAll the bestnnErikn
Viewing 3 reply threads
