December 13, 2020 at 10:15 pm
NS1985
SubscriberI am running a 2D DEM-DDPM case on fluent and I receive the following error after a certain point.Error at Node 0: Shear BCs not available for DEM ghost faces.nn999999: mpt_accept: warning: connection timed out after 120 secondsn0: mpt_accept: warning: connection timed out after 120 secondsn0: mpt_accept: error: accept failed: No such file or directoryn0: mpt_accept: error: accept failed: No such file or directoryn -
December 14, 2020 at 2:50 pm
Forum ModeratorWhat wall conditions have you set? n -
December 14, 2020 at 2:55 pm
DrAmine
Ansys EmployeeCovered by the documented limitations of DEM at Walls: No shear stress based Wall BC.n -
January 13, 2021 at 12:08 am
NS1985
SubscriberSorry for the late response!!!nI don't have any specified shear stress at walls. However, I don't receive the error after removing interfaces and running the model again.n
- The topic ‘Does anyone know why I receive the following errors?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
