3D Design
3D Design
Does fill command in Spaceclaim create a solid if thickness is specified?
    • PradnyaG20
      I am a beginner in Ansys and am trying to design a microfluid network. I imported my file in .dxf format in spaceclaim. When I use the command fill and specify the thickness, will the software create a solid/ extrusion of the closed channel profile of the given thickness? If not please help me understand what the fill and extrude commands actually mean and the difference in their funtioning.
      Maybe. It'll depend on the geometry.  If you can use a different import option as dxf can be unreliable. You may be better off building the model in SpaceClaim from scratch if it's fairly simple.
    • Keyur Kanade
      Please insert some images so that we understand the question in better way.
      Please check help document for fill and extrude.
      Please go through some tutorials.
      Keyur
