Does having a non-linear contact also trigger the geometric non-linearity with LARGE DEFLECTION OFF?
December 10, 2020 at 1:04 pm
Rameez_ul_Haq
SubscriberAnyone on this?n -
December 10, 2020 at 5:15 pm
SubscriberNo, you can have nonlinear contact with large deflection off.nAn example is a shrink fit or interference fit of a shaft in a hole. Very small deformations are involved.nThe contact definition even has a setting to speed up contact computations in this case, it is called Small Sliding and if you set that On, it will speed up computation, but it is off by default because the general case for contact is large sliding, and when you have that you must manually turn on Large Deflection.n
- The topic ‘Does having a non-linear contact also trigger the geometric non-linearity with LARGE DEFLECTION OFF?’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1688
1478
