June 5, 2023 at 10:04 am
Tan Tran
SubscriberI am doing a Raman enhancement effect by exciting a source of UV wavelength into a semiconductor material. So I did the simulation by adding 2 total - field scattered - field sources: 1 source with wavelength 633 nm and 1 source with wavelength 365 nm. To observe the change of electric field strength distribution. Does this make sense?
June 5, 2023 at 3:53 pm
Guilin Sun
Ansys EmployeeSince Raman enhancement is simulated linearly, it is not recommended to use two different sources at different wavelengths. Otherwise the signal normalization will be difficult as their time signals are not the same. https://optics.ansys.com/hc/en-us/articles/360034394234-Understanding-frequency-domain-CW-normalization
I would suggest that you use a broadband source from 365 to 633nm, and monitor only the two wavelengths if thet are the most desired, or monitor the broadband response.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
