June 4, 2023 at 5:20 pm
Tan Tran
SubscriberI am doing a Raman enhancement effect by exciting a source of UV wavelength into a semiconductor material. So I did the simulation by adding 2 total - field scattered - field sources: 1 source with wavelength 633 nm and 1 source with wavelength 365 nm. To observe the change of electric field strength distribution. Does this make sense?
June 5, 2023 at 7:54 am
Thomas Martineau
Ansys EmployeeHello,
Which software are you using ?
June 5, 2023 at 8:23 am
Tan Tran
SubscriberI am using ansys lumerical software
June 5, 2023 at 8:44 am
Thomas Martineau
Ansys EmployeeSorry I can't help on Lumerical, I will check with someone else.
For information, Lumerical topics should be in Photonics part of the forum: https://forum.ansys.com/forums/forum/discuss-simulation/photonics/ . Optical is for Speos and Zemax.
June 5, 2023 at 3:54 pm
Guilin Sun
Ansys EmployeeThe question is answered in another post Does it make sense to simulate 2 independent sources?
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2961
1449
1322
