February 21, 2022 at 10:17 am
gogogog
SubscriberHello,
Lumerical documentation shows that Lumerical charge solver uses displacement current in small signal analysis. However, does it include this displacement current in large signal transient 3D simulations in Charge solver ?
Thanks in advance.
March 2, 2022 at 8:54 pmKhashayar Ghaffari
Ansys EmployeeHi Thank you for your question. Yes displacement current is also accounted for in CHARGE transient analysis.
Best regards
- Error on Lumerical device
2564
2080
1299
1106
459
