April 21, 2022 at 1:36 pm
Chinchedu
SubscriberHi, in Ansys UDF manual it's written that "source term UDFs (defined using DEFINE_SOURCE) are called by ANSYS Fluent from within a loop on cell threads", and my question is does it even loop over boundary cells also.
Actually I have written a UDF using DEFINE_SOURCE for mass transfer based on saturation temperature, which is a function of local pressure. And stored saturation temperature in user defined memory. But in the post-cfd, near the boundary cells my saturation temperature is changing from 0k to 350K, and through the domain it's 350K. Does it loop over boundary cells?
April 25, 2022 at 2:42 pmRob
Forum ModeratorIt'll loop over the cells, not the facets. There is a macro to find the wall facet for a cell which might be what you're after.
April 25, 2022 at 2:51 pmDrAmine
Ansys EmployeeAlways try to disable node values when checking things in Fluent. DEFINE_SOURCE does definitely loop over ALL cells.
Viewing 2 reply threads- The topic ‘Does using DEFINE_SOURCE loop over boundary’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
