November 19, 2018 at 12:27 pm
Aloush993
SubscriberHello guys
please help me in this , is ansys good software for analysis of full 3-story structure ? and if so I know how to do column and use codes for it as concrete and add reinforcement , but I can't for full structure (except if I use beam dimension for column and beams without adding reinforcement )
and how to change from beam dimension to body ( this will help me in coding ) ?
Thanks so much
November 21, 2018 at 7:03 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
