May 24, 2023 at 3:33 pm
Yangqian Wang
Subscriber -
May 24, 2023 at 5:40 pm
May 24, 2023 at 5:46 pm
May 24, 2023 at 9:57 pm
Amrita Pati
Ansys EmployeeHi Yangqian,
I believe you would not be able to view the doping in this format directly since the visualizer shows the profile at all relevant points in space. But it should be simple to generate a line graph like this from the data by using your own script.Regards,
Amrita
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5162
3275
2453
