Discovery Import
Discovery Import
double click on .scdoc 2020R2
    • cbur
        Hello, Since 1 week (and the update of windows), several of our customers have lost the possibility of "double click" on .scdoc or .stp in SpaceClaim After having tried the modifications in the windows registry by adding   USERUNNINGSPACECLAIM = true" / UseLicenseMode = true in HKEY_CLASSES_ROOT SpaceClaim.Document Shell Open command HKEY_USERS Software Classes Applications SpaceClaim.exe shell open command it still doesn't work, do you have an idea? -->Error message: "No valid license file was found. How do you want to proceed?"
    • Charudatta Bandgar
      Hello charlie ,
      I am looking into this issue, I will get back to you as soon as possible.
      Regards.
    • cbur
      Do you have any news about this problem?
      Regards
        Hello charlie ,
        Does double click work if SpaceClaim is already open? Please go through this post, and see if it solves the issue.
        I have filed a bug (BUG ID: 367451), I have not heard back from the developers yet, I will let you know as soon as possible.
        Regards.
    • rg
      Hello Charudatta Bandgar
      I had the same problem today, no way to fix? I have already changed log files and scdoc files do not open with double click.
      Why does this happen to some users? on some versions of windows 10
      Best Regards
      • rg
        I have already changed  windows registry and scdoc files do not open with double click.
    • rg
      Charudatta Bandgar Hello
      The customer is asking me for an answer
      best regards
        I have asked the developers, Roberto . I will let you know when I will know more.
        Regards.
    • rg
      I am attaching the error it releases in the 2021 version if you need it
      Best Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      • rg
        do you have any news to solve this problem? did you understand the cause?
        Best Regards
    • rg
      More than a month has passed, the customer would like an answer
      Best Regards
    • rg
      Naresh Patre
      • rg
        charlie Hello
        were you able to solve the problem?
        Best Regards
      • cbur
        Roberto Hello ROBERTO,
        No sorry.... I got used to the idea and I gave up. I use drag and drop and I'm waiting for the next version (2021R2 hoping to have a good surprise)
    • Naresh Patre
      Hello Roberto
      Let me go through this discussion and get back to you.
    • rg
      Hello charlie
      I solved the problem by creating a new user with administrator rights and installing spacecliam inside C: ProgramData.
      Installing it in the default location was still giving me problems.
      The program data folder is shareable for all users it might be better to install it here.
      Before installing it I uninstalled spaceclaim and deleted all hidden folders
      Best Regards
Viewing 9 reply threads
