November 14, 2019 at 11:55 am
November 14, 2019 at 10:07 pm
Brian Bueno
Ansys EmployeePaesc
The registry key value should be set to the following:
"C:\Program Files\ANSYS Inc\v195\scdm\spaceclaim.exe" "%1" "/USERUNNINGSPACECLAIM=true" /UseLicenseMode=true
/UseLicenseMode=true is necessary to make Discovery SpaceClaim look for the subscription license. Without that set it will look for a floating license, which is why you get the error in the image you submitted.
November 18, 2019 at 7:59 am
paul
SubscriberBrian Bueno Which Key should i change? I already tried some of them described in a couple of forum posts, but none of them are working.
November 18, 2019 at 9:19 pm
Brian Bueno
Ansys EmployeePaesc
Each file type has its own key.
The easiest way to locate file types associated with SpaceClaim is to search the registry.
Use Ctrl + F to open the search, then search using only the Data field.
Search for: spaceclaim.exe" "%1"
Add the /UseRunningSpaceClaim and /UseLicenseMode commands to any keys pointing to C:\Program Files\ANSYS Inc\v195\scdm\spaceclaim.exe
3850
2629
1857
1252
600
