Discovery Import
Discovery Import
Double Clicking SpaceClaim file SpaceClaim doesn’t Open
    • tim.dukes
      Hi Support,
      I know this has been covered numerous times but I'm having an issue with Initially opening a spaceclaim file (scdoc)
      So SpaceClaim isn't open anywhere. I double click on an scdoc from Windows explorer and get the following message.
      If I double click on a STEP file or any other file associated to SpaceClaim I have no problems.
      Also once SpaceClaim is open I can double click an scdoc and it will open the file in a new tab as I want.
      Why when SpaceClaim isn't open does this message come up when double clicking an scdoc.
      I have searched the registry for every instance -spaceclaim.exe" "%1" and changed it to the correct value and still no luck??
    • Naresh Patre
      Hello Tim Dukes
      I have been discussing this double click issue with the development team and will update you as I have some information on this. Till then, I would request you to use the workaround that you have identified.
    • tim.dukes
      Thankyou.
      In 2021 the message is slightly different when double clicking see below if this helps at all.
    • Naresh Patre
      Hi Tim Dukes
      Sorry for getting back to you late on this query.
      I have submitted BUG 438860 for this issue. Meanwhile, I would request you to open the SpaceClaim application and then open the file using File menu or using drag and drop option.
    • tim.dukes
      Hi Naresh Patre
      Thankyou.
      I did manage to fix it eventually.
      Basically searched the whole registry for every instance of spaceclaim.exe" "%1"
      Then changed all to "C:Program FilesANSYS Incv211scdmspaceclaim.exe" "%1" "/USERUNNINGSPACECLAIM=true" /UseLicenseMode=true
      This fixed the issues but will most likely have to be done for every new version.
Viewing 4 reply threads
