Double encapsulation (droplet)
    • minonti
      I wanna know if i can do an drop inside drop and this two drops inside a third drop with ansys
      Is it possible to show that in ansys ?
      It is with the multiphase models, but will be computationally expensive. What do you want to learn from the model?
    • minonti
      How can i make evrey droplet with a color to show the difference
      Which model are you using?
    • minonti
      VOF
      In which case not easily: the phases can be coloured as can other values (via contours) but not the "droplets" as such.
Viewing 5 reply threads
