Doubt about layered section in Ansys workbench
    • Vivek Gangishetty
      I have modeled a simple plane rect surface in design modeler and then applied layered section in Mechanical I have applied 4 layers of 1, 5, 3 & 10 mm layers with diff materials. How can I view which thickness is at top or bottom like we see in APDL ? It's showing only single thickness of combined 19mm.
      Thank you
    • Erik Kostson
      Not sure this is possible – first layer should be on the bottom as the layered section worksheet says.
      Erik
