March 26, 2021 at 8:27 am
Aitor
SubscriberI am injecting particles with a diameter of 2.5 mm, with only one physical model enabled: breakup (KHRT). When displaying particle tracks, I see that there are many particles with diameter greater than 2.5 mm. Why is happening this? n -
March 26, 2021 at 1:42 pm
Ansys EmployeeCheck through the settings in DPM models. Also click on Stochastic collision, turn off coalesence and then turn collision back off. It shouldn't do anything but it was a glitch in the original model. n -
March 29, 2021 at 8:29 am
Aitor
SubscriberI have clicked on stochastic collision, turn off coalescence and then turn back collision off, even though I get the same solution. I have checked everything, and I have only one physical model enabled: Breakup. How can particle diameter grow if I do not have coalescence enabled?n -
March 29, 2021 at 10:32 am
Ansys EmployeeI assume the injection is single size and no (wall film) splashing on walls? n -
March 29, 2021 at 10:35 am
Aitor
SubscriberI assume the injection is single size and no (wall film) splashing on walls?https://forum.ansys.com/discussion/comment/113034#Comment_113034
Yesn -
March 31, 2021 at 6:44 am
Aitor
SubscriberAnyone can help me? It seems that it is a bug of Fluent R2021.nI would also like to ask if it is possible to add a UDF in order to disable breakup if a certain condition is met. This is a way to model solidification of the discrete phase.n
Viewing 5 reply threads
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
