May 16, 2022 at 7:01 pm
Dave Groff
SubscriberIs there a way ?
May 17, 2022 at 6:26 am
Subashni Ravichandran
Forum ModeratorHello Dave Groff
Can you please elaborate on what you are looking for?
If you are looking for Annotations and symbols, you can find some of the standard ones in the 'Details' Tab under 'Annotation'. (see below image)
If you would like to Create new symbols, you can do from the 'Create' option in 'Symbols' under 'Details' tab. The created symbols will appear in Inset> Local
You can also 'Import' a new symbol library, from Insert>Add symbol library (image below)
May 17, 2022 at 11:05 am
May 19, 2022 at 9:00 am
There are no libraries for symbols that we offer apart from the ones already on SpaceClaim. This symbol can be created separately and imported into SpaceClaim.
May 19, 2022 at 11:09 am
Dave Groff
SubscriberId imagine you by now get how this is a bit of a issue ? A dowel pin is a fairly standard thing and I would consider it a bare minimum item.
- The topic ‘Dowel Pin Symbol ???’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1688
1478
