download the tutorial resources
    • kenchan
      Hello everyones,
        how can i download the resources which was used in the tutorial?  Thanks!
      such as
    • Vishal Ganore
      Where did you find this tutorial?
    • kenchan
      em
      I'm a student,and my friend shared this tutorial for me.  thanks .
    • noah
      hello Admin
      I am using the student version of Ansys but when try to run my structural or thermal analysis, this is what i get.
      Your product license has numerical problem size limits, you have exceeded these problem size limits and the solver cannot proceed.
      please i need help
    • Vishal Ganore
      em
       You can go to product documentation, Refer Fluent, you will find similar getting started tutorial.
    • Vishal Ganore
       Student product can handle 32K nodes/elements. Please check your mesh, apply different meshing methods and try to get it below 32K.
    • rathorey
       No one is providing the download link for the above tutorial. what is the use of this discussion? No one is getting the benefit of this discussion forum.
      The number of the tutorials are provided in the ANSYS  FLUENT Tutorial Guide pdf for practicing but we are unable to find the link of resources file for downloading and practicing. How one can do the practice without the resource files.
      Please provide the downloading link of the above tutorial not only for the above tutorial but also for the remaining tutorial as well which are described in the ANSYS  FLUENT Tutorial Guide pdf.
    • a.sarmadi
      As my friend said, I have the same problem and definitely have the same request to provide all of the tutorial input files or else your tutorials are useless!
    • DrAmine
      Can you access the ANSYS Help following this link? Here you might find the standard tutorials.
    • peteroznewman
      @abenhadj,
      That link points me to this site, but students can't get an account on the Customer Portal.
      Students who installed ANSYS Student 19.1 can open the ANSYS Help through the Windows Start menu.
      One inside, navigate to the Fluids section where the tutorial files are stored in zip files.
    • DrAmine
      I will check that
    • DrAmine
      after checking and installing the Student version on my private PC I can confirm  what I have already said that Students might access the online Help and hence all tutorials.
    • peteroznewman
      Hi abendadj,
      I had another student check this and they had the same result as I did, the link lead to the Customer Portal sign-in page.
      However, I did figure out a workaround and posted a discussion that will be more easily found.
      Best regards,
    • DrAmine
       I have highlighted that with my colleagues to update the ANSYS Student Support Ressources and thanks for the workaround.
    • DejanRS
      Hi everyone, Ansys student version user here, I tried to workaround as described above but had no success in finding tutorial input files. Can someone post Fluent tutorial files here please, or help somehow? Thanks, kind regards...
    • diquetegusta
      Any news about letting students access to the support resources of your tutorials (youtube videos, for example)?
      The YouTube channel is open to all. If you click on Help is it hitting the password system again? Does Peter's bypass not work?
Viewing 16 reply threads
