Discovery Import
Discovery Import
Downloading and Installing Algoryx Momentum
    • joao.gaspar
      I just got a license for ANSYS Discovery Algoryx Momentum. I wonder now where i can download  it and how i should add to Discovery Spaceclaim.
      Hope someone can help me :)
    • Brian Bueno
      Joao Gaspar
      First, log in to your account page and make sure the Algoryx Momentum subscription has been assigned to your account.
      Launch SpaceClaim.  If you do not immediately see the Momentum tab in your toolbar, select File > SpaceClaim Options > Customize > Ribbon Tabs.  Enable the Momentum tab.
      Once that appears, you should see a Download button for the Algoryx Momentum package.
      Install Momentum and restart SpaceClaim.  You should now be able to access those functions.
      Make sure to temporarily disable any antivirus or Windows Defender security measures during the installation.
      • mariarita De Rinaldis
        Brian Bueno
        Hi! I followed your instruction but I can't find Momentum option among Ribbon Tabs. What can I do?
    • joao.gaspar
      Hi!  BBueno_ANSYS
      Thanks for you help but still having the problem.
      I already check my subscrition and is there ready to be used as you can see in the image.
      When i go to SpaceClaim Options » License and try to activate Momentum i get a error message: ‘There are no current ANSYS subscrition that enable capibility ANSYS Dynamics for Spaceclaim Algoryx’
    • Brian Bueno
      Joao Gaspar
      Have you signed into your account on the software since adding this new license?  The software will only check for subscriptions every 30 days or so on its own.  You may need to log in again.
      In the top right corner of the main window, you'll see a small user icon.  Click that and log in again.
      Make sure your firewall is temporarily disabled.
    • joao.gaspar
      BBueno_ANSYS
      I manage to install Dynamics manually, however i'm still having a problem with license.
      When i start SpaceClaim, he is unable to find a valid License, and when i check my subscritions is unused.
      I already did login iniside SpaceClaim.
    • Brian Bueno
      Joao Gaspar
      Have you tried releasing the license from your account management page and reactivating the software on your PC?
      I think we may need to force it to acquire the license again, and then maybe it will pick up all the subscriptions that are available.
    • joao.gaspar
      BBueno_ANSYS
      I just did that and it works!
      Thanks a lot!
    • k.katayama
      Brian Bueno
      I can use momentum on my laptop, but somehow it doesnt work on my desktop.
      When I click the check-box for momentum in the license tab, the message that was mentioned above shows up.
      I did follow your instruction but cannot still activate my momentum account.
      The ribbon is there now because I manually installed momentum, but I didnt appear before that as well.
      Could you tell what might be the cause of it?
       Thank you.
      • Naresh Patre
        Kohei
        I see that you have a Algoryx Momentum but it not activated on any device. Can first activate it through command line using below steps:
        1.    Launch the Windows Command Prompt from the start menu by typing "cmd".  Right click the Command Prompt application and select Run as Administrator.
        2.    In the command prompt, type in:
        cd C:Program FilesANSYS IncShared FilesLicensingwinx64
        (this is the default installation directory of Discovery products. If you have installed it at a different location, enter the appropriate path where ansysls_client.exe is present)
        3.    Once in that directory, run the following command:
        ansysls_client.exe -ActivateLicenseEntitlement
        In above command, replace with your Algoryx activation id. Also, make sure that you don't specify the angular brackets <> in the command. You can find the activation id in the txt file that you receive or from your Discovery Account page under Manage Subscriptions section.
        Once activated, SpaceClaim License panel and activate Momentum license.
        Let me know if you face any issues.
    • k.katayama
      Naresh Patre
      It works now that the license is manually activated.
      Thanks so much for your help.
Viewing 8 reply threads
