June 4, 2020 at 4:58 am
JASONCHANG8888
SubscriberHello everyone, I encountered this problem when the system was coupled
(DP 0) Participant Solution 1 encountered a fatal error. Message: The Mechanical beginning time 2 is different from the system coupling service beginning time 0. This may have been caused by changes made to the Mechanical setup or upstream data. Please do not save the project if you would like to recover to the last saved state.
I would like to ask how to set Thank you
This is a transient structure
This is fluid
This is coupling
July 1, 2020 at 7:18 pm
NicoKlein
SubscriberFirst of all, the time in transient structural does not match the end time in system coupling, which should not cause the problem - just a friendly reminder.
Secondly, this error usually occurs, when you started the system coupling - stopped or error for whatever reason - made some changes and then restarted it. This is where this error occurs, you need to remove the transient structural system completely and set it up again.
Hope that helps and sorry for the late answer.
Nico
3744
2573
1821
1236
594
